Causes for this code may include: Engine vacuum leak (large) Defective oxygen sensor/s Burnt, chafed, broken, or disconnected wiring and/or connectors Engine exhaust leaks A faulty mass air flow or manifold air pressure sensor Bad fuel pump or clogged fuel filter
Read more at:
https://www.obd-codes.com/p219a
Copyright OBD-Codes.com
Troubleshooting:
All misfire codes, throttle position sensor codes, manifold air pressure codes, and mass air flow sensor codes should be addressed before attempting to diagnose a code P219A. The engine should also be running smoothly and efficiently. If it is determined that either a rich or lean condition exists (with the engine), this must be repaired as it may be the cause of the P219A being stored. You will need a diagnostic scanner, a digital volt/ohmmeter (DVOM), and a source of reliable vehicle information in order to accurately diagnose a code P219A. You may save yourself time by searching for technical service bulletins (TSB) that replicate the code stored, vehicle (year, make, model, and engine), and symptoms exhibited. This information may be found in your vehicle information source. If you find the right TSB, it could yield a speedy solution to your diagnosis. After you connect the scanner to the vehicle diagnostic port and retrieve all stored codes and pertinent freeze frame data, write the information down (in case the code proves to be an intermittent one). After that, clear the codes and test drive the vehicle until one of two things happens; the code is restored or the PCM enters readiness mode. The code may actually be more difficult to diagnose if the PCM enters readiness mode at this point, because the code is intermittent. The condition which caused the P219A to be stored may need to worsen before an accurate diagnosis can be made. If the code is restored, continue with the diagnosis. You may obtain connector face views, connector pinout charts, component locator charts, wiring diagrams, and diagnostic flow charts (pertaining to the code and vehicle in question) using your source of vehicle information. Perform a visual inspection of related wiring and connectors. Repair or replace wiring that has been cut, burned, or damaged. If the engine is running smoothly and the code P219A/P219B continues to be reset, start the engine and allow it to reach normal operating temperature. Allow the engine to idle (with the transmission in neutral or park). With the scanner connected to the vehicle diagnostic port, observe oxygen sensor input data on the data stream. Narrow the scope of the data stream to include only pertinent data and you will get a faster response. If the oxygen sensors are functioning normally, voltage on pre-cat oxygen sensors will cycle continuously between 1 and 900-millivolts once the PCM enters closed loop operation. Post-cat sensors will cycle between 1 and 900-millivolts as well but they will settle at a certain point and remain relatively stable) compared to the pre-cat sensors). Oxygen sensors which fail to cycle adequately should be considered defective if the engine is in good working order.
Read more at:
