Paint Make-Over (PIC HEAVY)
BlkYukon95
Green Bay
Okay, so I was getting sick of looking at my scratched up and dingy paint on my Yuk. I bought it 4 weeks ago and it has been fricken cold up here so I havent been able to do anything about it, until last saturday. I was able to use my buddies heated garage and went to work. This is what I started out with...
So as you can see the hood was from a junk yard and felt like it had hair on it. I started with a clay bar and here is a pic of the start of that. HoodClay.jpg
That was able to knock down most of the junk on the hood. I then took some 1500 sand paper and color sanded some of the scratches out of it. I then used the diamond cut 2.0 maguires and this is a pic of half of the hood done. HoodHalfClay.jpg
So I claybared the entire truck and wet sanded when necessary. Then I used the meguiars diamond cut 2.0 with a wool pad on the entire truck to remove the sanding marks and get out all of the light imperfections.
I took some time and sanded down the rust on both sides and filled where necessary (until I have time to weld in some cab corners this will have to do).
I then used the Meguiars Dual action cleaner/polish with a black foam pad on the whole truck to get rid of my swirls form the compound.
Then I used the Meguiars Swirl Free Polish to give me a deep shine with a yellow foam pad.
To finish it off and lock in that shine I used the Meguiars Deep Crystal Carnuba wax applied with an orbital buffer and wiped it off with a microfiber towel.
Final outcome.
Administrator
Nice results!! :waytogo:
dsltrc
Virginia Beach, VA
i think he works for Meguires!!!!! looks good... i'm thinking about doing the clay bar this spring... i used it about 8 years ago and got great results...
Administrator
Then he's pimpin' his work place :waytogo:
B
BlkYukon95
Green Bay
After I re-read that it does seem that way. I did detail though high school and college and the shop used Meguiars, so I may be biased. Nothing to buff in my office though.
Administrator
When taking care of the rust spots along the bottom did you just use rattle can black for now once it was prepped? In the pics you can't even tell but I'm sure in person and up close you most likely could.
nook
