Parasitic draw with modules out
yobenny
2001 Yukno-
A shop disconnected the EVM and BCM a bus bar gauge cluster and a few other plugs inside trying to solve a crank/no start where the fuel pump and other things not engaging.
Couldn't find it, said both modules are fried, based on not able to connect to them.
Towed it home all taken apart.
Did a battery and draw test, with all that disconnected, it's still pulling between 1.2 and .9 amps.
Should I plug everything back in before I search for the draw or leave it disconnected?
I have a new programmed EVM but am afraid to plug it in until I resolve this 1 amp draw and thinking I can just put the old one in.
Thanks for the advice fellas.
strutaeng
Dallas, Texas
EVM? Is that the engine computer?
Do a "voltage drop" check on each fuse and see which is the one drawing. At this point, leaving those modules unplugged or plugged probably doesn't matter because they are likely not the culprit.
The IPC fuse that powers the cluster is a known issue and has to do with the cluster solder breaking down over time and causing the draw. At least on the 03-06 models. I can't remember if it also affects the 99 (trucks) or 00-02? I never had cluster amp draw on my 99 Silverado, but did have the dimly lit gear selector indicator.
yobenny
yobenny
It has a 3.1 amp draw continuous, I just pulled all the fuses, no change.
What am I missing?
I will do a voltage drop on them now.
strutaeng
Dallas, Texas
H O-Lee Chit Batman! That's a huge draw.
If you are in the colder regions of the States and can get ahold of an infrared camera, you can find the offending circuit, actuator or module that's causing this. Whatever is staying on will be generating a LOT of heat at 3.1 amps!
cpederson
