Passenger rear window doesn't work
burpman
Hey, folks...I have a 2005 Denali. My passenger side rear window doesn't work from both switches (driver and passenger). I just hear a clicking sound. L'il help here, please...THANKS!!!
mmeachem
Motor is gone or blown fuse but more than likely a motor since it's clicking
While your there replace the whole unit (regulator & motor) only $50 and is a DIY job only 30 mins
03YukonNH
Manchester, NH
Try holding the window switch while giving the door panel some quick whacks with your fist. Should free up the motor. Sounds like its stuck. But you will probably have to replace it since this is just a temporary fix to get it moving.
ScottyBoy
Shreveport, La
I agree with everything above, except for the part about the regulator/motor assembly being only $50. The fronts are that cheap, but not the rear ones. Those are more like $100-$130, or at least they were 2 years ago when mine went bad.
Shawn74
Ok I know about the motor but you said replace the regulator while your there. What does the regulator look like? Sorry for a dumb question, but I don't know and I have this same issue with the same window, and I have done the door panel beat down and still dont move. LOL. thanks for your help
662longsleeve
