Passenger side Seatbelt Retractor
xanatost
Lafayette, La.
Dose anyone know how to take apart the seatbelt retractor in a 98 Tahoe? I have a new plastic cover i need to replace. I have the seatbelt out but need to see how to take it apart. Need help with ASAP if possible.
MO351
Did you ever get this done? I took mine apart on the side where the lock is at and is operated by the little weight/inertia operated thingy (for lack of actual term, lol). I put it back together, thought it was working correctly after that and then after I got everything remounted inside the truck it locked up again and won't release. There's like a blue gear looking thing inside it with a black funky shaped gear inside the blue gear with a blue lever that has a spring on it. As the black gear turns it moves the blue lever up/down which the blue lever helps operate the inertia lock. I think I may not have that back in correctly. Do you or anyone know how to reset it correctly?
X
xanatost
Lafayette, La.
I never got around to it yet. Got stuck on a few other projects. How did you pull yours apart??
Jayhawkeye3
