Performance Ignition Kit??
knoslf
Thornton, CO
Anybody running their obs Tahoe/Yukon with one? If so please explain to me what this does, does it make our trucks faster? What is the purpose for these? Heres one I saw on the net and its description as well...If you have a performance ignition kit please explain how it has enhanced your truck's performance if any and what kind(model ##?) you're using...I have a 99 Yukon SLT 4dr 4x4..
'ACCEL VORTEC IGNITION KIT -- 100 amps; Kit includes the new CNC-machined aluminum Vortec distributor, Superstock coil, and Extreme 9000 plug wires; Contents are made from factory matched components for best reliability; A great ignition upgrade for weak factory ignition; With 90-day Accel limited warranty.'
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Msd ftmfw. Multiple spark discharge, higher power spark, red in color:), extremely durable. I have a full system minus cap and rotors which burned out in me. Another story. Other wise it ensures the the fuel charge is completely burned.
K
knoslf
Thornton, CO
Thanks SunlitComet, btw what does ftmfw mean? And does higher power spark = more noticeable power?
SunlitComet
OBS Jedi-Do Good
a little. your fuel is getting burned already. the system just makes it a more complete burn. it is often hard to tell the difference in the butt-o-meter.
992dr
Eastern N.C.
My MSD ignition system, part numbers through Summit.
Cant go wrong with MSD
MSD 6A ignition box 6200
wiring harness 8877
coil 8231
spiral core wires32163
cap and rotor 8017
992dr
Eastern N.C.
Well, considering MSD isnt giving me a check for advertising and the fact that I like the factory look. No tomatoes in my face.
SunlitComet
OBS Jedi-Do Good
but it's a red colored tomato. factory look with red cap and rotor and box. guess with the black wires and coil we will call it even. Do me a favor if you ever have problems with the cap/rotor of any sort get some pics of it and let me know. want to study long term effects on the design in use on the oem distributors on the obs small/big block engines.
REGolfPro
