Martinjmpr
For the last year or so I have been getting intermittent "Service Tire Monitor" messages on my Drivers Information Center (DIC.) This ONLY happens on long drives after running for several hours (IOW it never happens when I'm driving around town or to and from work.)
I had the tires put on my Discount Tire in 2016 and just recently took it back for a rotation. They said they would "service" the TPMS sensors, but on the next long drive, sure enough I got the "Service tire monitor" message. I should point out that my TPMS low pressure light is NOT on and all 5 tires have correct pressure.
Second problem: After getting the "Service 4wd" message on some previous 4wd trips, I pre-emptively had my encoder motor replaced. As near as I can tell it works fine and I have used it in all 4 modes (2wd, Auto 4wd, 4-hi and 4-lo) with no problems. Just recently, when I started the truck the "service 4wd" message came on again. I cycled through 4-hi, Auto 4wd and 2wd and it all seemed to work fine with no other error messages.
At this point I'm thinking these are just "phantom messages" popping up from time to time maybe because of a faulty or failing sensor. The components in question (the 4wd system and the TPMS system) all seem to be working fine, I think it must be the "warning system" that is going goofy on me.
Has anyone else had similar problems with DIC messages that don't seem to make sense?
