Picture of Yukon Denali
longstand
Sorry guys. i been busy..
I have finish the Denali. the Interior/exterior and the TIRES :party33: new rims too.
Here is some pictures of the outside
Administrator
Looks good man! :)
99Yuk
Northern Ontario, Canada
Not too shabby at all!!!
And hey look, all the tires are the same size!!!! :)
And it only took the body shop four months!!!! Hope it came out ok for ya this time round?
What are your next plans for it?
Looks like you got yourself a good rig now anyways.
longstand
longstand
I need to install the Steering stablizer. and figure out why is Tilting Side ways.
One side is higher on the other side.
I got a wheel alignment also. so its not so bad driving it anymore
it will be about a few weeks before i do anything to this Denali. i just got my 07 Civic Hybrid, and it has NO compression on cylinder 2. and 2 spark plug was dissolve "no tip or anything"
SunlitComet
OBS Jedi-Do Good
unknown at this time.
On a level ground measure the wheel opening height side to side and compare the difference. do front and back. Which ever front or rear end is worse go to that end and the side with the lowest measurement and you will probably find the problem in the form of a torsion bar or leaf spring out whack.
BTW very nice.
longstand
longstand
Thanks for the advice again.. hopefully is just the torsion bar need to be readjusted again.
I got the wheel alignment, then i readjust the torsion bar. do i need to get anther wheel alignment because I adjustment the torsion bar?
I wish you was my neighbor
95escahoe
nice looking truck and nice rim/tire combo
SunlitComet
OBS Jedi-Do Good
Maybe a little tweek.
Marcasket
