Pioneer sph-Da01. 2 questions...
norcalpilot
sacramento CA
Hey two quick questions for anyone interested in helping...
1 how hard is it to fit this unit into my 97' 2 door console?
And
2 I've upgraded front speakers to Polks and rear to 6x9 Pioneer...will this head unit push the 4 speakers adequately to eliminate the need for a 4 channel amp? My plan is this head with a JL audio center stealth box 10" sub. (just 1 amp)
Any thoughts or recommendations ? ( this is not my specialty area)
Thank you all
norcalpilot
norcalpilot
sacramento CA
6x9s are in rear stock position. Pioneer is a bit shallow-er than others. Only slight dremel was needed.
Thanks sunlit. I like that templet. Just sucks that it doesn't look stock.
What about keeping stock head unit and adding a 4 way amp? Will that work? Sound good?
So my plan is ... JL audio stealth box / mono amp ( not sure on power?) / 4 way amp (power?) and keep stock head unit.
Thoughts?
Btw fronts are 6.5 polks rear pioneer 6x9
---------- Post added at 11:52 AM ---------- Previous post was at 11:47 AM ----------
Has anyone seen this piece of work? Nice ride! I'd like to do a sub in the back just like this one. Anyone know where I can buy one? I have no clue how to make something like that but it's very clean looking
http://www.autotrader.com/fyc/vdp.j...s=25&cardist=1424&standard=false&rdpage=thumb
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I went single din and added modules in the glove box and put a 5-way under pass seat and dual subs under rear seat. I am happy.
It had better have a stroker and still to much money I think.
norcalpilot
norcalpilot
sacramento CA
Looks good sunlit. Can you recommend a good 5 way? I've heard they aren't as reliable as doing 4 way and a mono? I'd like to just do one under pass seat too.
(btw...noticed your pics... You a pilot?)
Yes, that rig is way over priced! I'd go 13-14$k but that's a lot of cash seeing as a bank will only give like 8$k MAX for a 2 door hoe!
SunlitComet
OBS Jedi-Do Good
Unemployed aircraft mechanic. I use the Kenwood Excelon XR-5S with no regrets. 80wx4 + 375wx1 continuous. Very small footprint. Can get it for $300. A picture of it is in my album. It drive polk 6.5" componenents in all doors and two Polk MM1040 subs.
b18cls1
