Plan to install Transmission COOLEER on Denali!!!
longstand
Well. just to be safe and something todo. iam going to install a Transmission cooler for my Denali.
is there already a transmission cooler stock that's already been install on this kind of a SUV.
I notice that there s a Cooler on front of my radiator.. dont know if that is for the A/C. i will check it out ones my Denali is back from the Body shop from the body work and pain.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Besides the the standard cooler lines from your transmission to the radiator side tank a factory aux cooler will look like a small radiator about a square foot in size and would probably be located to the right side of and in front of the a/c condenser which is in front of the radiator.
The condenser takes up a similar footprint size like the radiator but it should have a distinctive color difference over the radiator.
If you happen to have a pair of cooler lines going to each radiator side tank then your engine oil cooler is pre installed too.
---------- Post added at 01:13 PM ---------- Previous post was at 01:12 PM ----------
Take your complete vin number to a dealer to decode and it will give you a build sheet for your truck with the options installed. It costs nothing.
longstand
longstand
1999 GMC Yukon Denali Utility Performance & Efficiency Standard Features
Auxiliary oil cooler
Auxiliary transmission cooler
5,733 cc 5.7 liters 8 V engine with 101.6 mm bore, 88.4 mm stroke, 9.4 compression ratio, overhead valve and two valves per cylinder
Unleaded fuel
Fuel economy EPA highway (l/100km): 14.7
Multi-point injection fuel system
114 liter fuel tank
Power: 190 kW , 255 HP @ 4,600 rpm; 330 ft lb , 447 Nm @ 2,800 rpm
Well I dont think i need to install any COOLER. it already has one..
Auxiliary Tranny COOLER.
weeeeeeeeeeeeee
ezmoney1981
