Please give me some recommendations; lowering on 26s
trdhulk
Ok, i'm about ready to replace my shocks and struts, so i want to go ahead and lower it at the same time.
I like the look of a 3/5 drop the best. I'm sure i'd have to trim the fender liners. does anyone know of a template?
what is the best kit for the money that will replace my tired shocks and struts?
and i would love to see some pictures from anyone who has a 3/5 or 4/5 drop on 26s.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Here is one kit the 2/3-4 adjustable and new front/rear shocks. The front struts lower the truck 2 inches and ride is nice
http://www.tbssowners.com/store/index.php?act=viewProd&productId=106
if your on 305 30 26 will be good. If you want to lower lower ie 3/5 you would need to go wtih this kit and 295 30 26 or 305 30 26
http://www.tbssowners.com/store/index.php?act=viewProd&productId=140
---------- Post added at 09:04 PM ---------- Previous post was at 09:02 PM ----------
heres one
trdhulk
trdhulk
damn, double the money for one more inch
im running 295/30/26 now but i want 305s.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i would do the belltech 2/3-4 kit and you will be good.
KMeloney
Rumor has it that the move up to 305s is one of the major contributors to rubbing. So, keep that in mind.
NASTY GM
Nor Cal
If you want to save a few bucks get the Belltech 2/4 and cut a little of the factory front coil. That will get you a 3 ish front drop.
ASHRAF
I really like the look of belltech 2/3 drop, I think you would find that as the perfect setup too :)
-AJ
trdhulk
trdhulk
do you have a part number for the kit you recommend? i see so many different kits when i search
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
2509 belltech
5305 springs
35323 spacer
6651 shock extenders
That are the part numbers in my kit
KMeloney
Don't go searching. Drop Tony an email, and say "Tony, I need your 2/3 drop kit for my truck." And then Tony will email you back in 10 minutes with the kit you want/need. Or, just go into any of the other lowering threads. He's selling mostly the same one kit at this point, since the springs and all are dialed in.
haloOne
