Please help me!!!!
weatherfordjacey
Okay guys I have a 94 chevy blazer 350 4wd. I recently replaced my oil pressure sensor to hopefully fix my low oil pressure problem then after replacing that tried to start it and my starter was grinding something nasty on the flywheel shimmed it every which way but it still did it and I found a low spot on the teeth so I had to replace that to got it all put back together and replaced distributor cap and ignition module it tried to start but it was shaking so bad I didn't try to keep it running so I double checked everything and noticed this wiring harness on the passengers side of trans and I can't for the life of me remember/find where it goes the wires are brown and green
I really need my truck running so I stop having to take my lunch break from work at 3 to go pick my girlfriend up because I have her car and she goes to work 30 mins before I do
Sent from my SAMSUNG-SM-J120AZ using Tapatalk
edonwheels73
Looks like one of the transfer case wires.
Sent from my SCH-I545 using Tapatalk
devingcore
