please help solve transmission problem!?
bankout86
1997 Tahoe
I took the truck to a local transmission shop and they told me that I'm probably going to need a new transmission!?! I'm not so sure of that.
My truck drives and shifts perfectly for about the first 10 - 15 minutes of driving.
After that it starts to shift hard between gears.
I put the truck in neutral and turn it off. Once restarted the problem goes away for another 10 - 15 minutes.
It has 140,00 miles and I have out 25,000 on it with this problem occuring.
I've noticed a lot of people have had this same problem. But reading through tons of forums I can not find one answer that agress with another one about a solution.
Anyone know/ ever fixed this problem before?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Shifting suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. May be intermittent
CheckThrottlePosition Sensor (TPS).for smooth electrical response. If the response is jumpy or erratic at all.
gy_psi
