PLEASE HELP Transmission shifting problum
jlenkowski
hi I'm new to the foruns I naught a 99 Gmc Yukon about a year ago and shortly after the enging through a main bearing so I replaced the engine. Apon first test drive the transmission shifted fine in all gears except D at 35 mph the engine revs and no power is applied. I replaced the transmission and torqconverter and no chang. Only code is a pos1860. I don't know where to start.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
P1860
182363868
DTC P1860 TCC PWM Solenoid Electrical (1 Of 3)
182363869
DTC P1860 TCC PWM Solenoid Electrical (2 Of 3)
58833234
DTC P1860 TCC PWM Solenoid Electrical (3 Of 3)
58833227
TCC PWM Solenoid
CIRCUIT DESCRIPTION
The Torque Convener Clutch Pulse Width Modulation Solenoid Valve (TCC PWM Sol. Valve) controls the fluid acting on the convener clutch valve. The converter clutch valve controls the Torque Converter Clutch (TCC) application and release. The solenoid attaches to the control valve body within the transmission. The solenoid receives ignition voltage through circuit 1020. The Vehicle Control Module (VCM) controls the solenoid by providing a ground path on circuit 418. Current flows through the solenoid coil according to the duty cycle (percentage of ON and OFF time). The TCC PWM Sol. Valve provides a smooth engagement of the TCC by operating during a duty cycle percent of ON time. When the VCM detects a continuous open or short to ground in the TCC PWM Sol. Valve circuit or the TCC PWM Sol. Valve, then DTC P1860 sets. DTC P1860 is a type A DTC.
CONDITIONS FOR SETTING THE DTC
  • The system voltage is 10-17 volts.
  • The engine is running.
  • The VCM commands first gear.
  • All of the above conditions are met for 5 seconds and either of the following fail conditions occurs for 5 seconds:
  • The VCM commands the solenoid ON (90%) and the voltage remains high (B+).
  • The VCM commands the solenoid OFF (0%) and the voltage remains low (0 volt).
ACTION TAKEN WHEN THE DTC SETS
  • The VCM inhibits TCC engagement.
  • The VCM inhibits 4th gear if the transmission is in hot mode.
  • The VCM freezes shift adapts from being updated.
  • The VCM illuminates the Malfunction Indicator Lamp (MIL).
CONDITIONS FOR CLEARING THE MIL/DTC
  • The VCM turns OFF the MIL after three consecutive ignition cycles without a failure reported.
  • A scan tool can clear the DTC from the VCM history. The VCM clears the DTC from the VCM history if the vehicle completes 40 warm-up cycles without a failure reported.
  • The VCM cancels the DTC default actions when the fault no longer exists and the ignition is OFF long enough in order to power down the VCM.
DIAGNOSTIC AIDS
  • Inspect the wiring for poor electrical connections at the VCM. Inspect the wiring for poor electrical connections at the transmission 20-way connector. Look for the following conditions:
  • A bent terminal.
  • A backed out terminal.
  • A damaged terminal.
  • Poor terminal tension.
  • A chafed wire.
  • A broken wire inside the insulation.
  • When diagnosing for an intermittent short or open condition, massage the wiring harness while watching the test equipment for a change.
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic chart.
4. This Step tests for voltage to the solenoid.
6. This Step tests the ability of the VCM and wiring to control the ground circuit.
8. This Step tests the resistance of the TCC PWM Sol. Valve and the Automatic Transmission Wiring Harness Assembly.
---------- Post added at 02:43 PM ---------- Previous post was at 02:39 PM ----------
I think you may have damaged a wire in the process.
J
jlenkowski
That's what I am afraid of how would I go about diagnosing that. I know the old transmission had a lot of water inside it that sat around for a long time replaced all the rusty internals on rebuild but we did not replace the harness. I'm wondering if maybe the wireing harness inside is damaged because of the rust.
SunlitComet
OBS Jedi-Do Good
do a continuity test between the pcm and tranny connectors. it is the brown wire wire in the harness just disconnect the tranny connector and pcm connector. tranny side is terminal "U" . of two sets of four inline holes the set you want has two used and two unused the terminal you want f that set is not the one at the end but the second terminal it will have an unused hole on the other side of it.
Transmission and Drivetrain
62392563
Light Duty Transmission/ Heavy Duty Transmission
BTW light duty tranny is yours. the pcm C2 connector is labeled RED pin #7
Engine Control Module
58832982
Connector End View
also with key on check for 12volt power on pink wire pin "E" of tranny connector. if no power check trans fuse.
J
jlenkowski
Thanks a lot I really appreciate the advice I will give that a try.
BigBodyBurban
