Popping in front end
BADRIDES
I'm getting some popping in the front end of my 02 Tahoe since I lowered it. All I did was put 2 inch belltech spindles on the front. It is worse when turning sharply with the brakes on or if the front end is put in a bind. Might go a week with no popping and then all of a sudden start again and then quit for a week. I stood on the running board to wipe the top off and something popped. I have re-tightened everything 2 times. Any ideas?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
might have damaged balljoints when popping them off.
BADRIDES
BADRIDES
Checked everything at work today and everything is tight. Ball joints, tie rods, wheel bearings all ok. But I can still stand on the running boards and rock it from side to side and you can hear a squeaking type noise coming from the front. U can hear it when u hit a small bump in the road. Any ideas?
BADRIDES
BADRIDES
New greaseable sway bar bushings fixed the problem
ButtlickerPrices
