Post DOD Delete engine noises
blackjack
Palmetto Bay, Fl
My OEM GM lifters soaked in fresh oil for about a month. I also used an old push rod and pressed the plungers in them to push out the air until they were solid. I like my overkill for assembly and first start. It's only overkill until it isn't.
Unfortunately the VLOM got thrown out a week or so ago.
CHECK PUSHROD LENGTH! THIS WILL TAKE A BIT OF LEARNING BUT WORTH IT. WHEN CAM, SPRINGS, LIFTER TYPE ETC CHANGE IN THIS CONFIGURATION THE STOCK AFM PUSHRODS MAY BE TOO LONG AND CAUSE ISSUES OBVIOUSLY. EVEN IF THE 7.400 SHOULD NOW BE 7.375 OR WHATEVER YOUR IDEAL NUMBER IS AFTER USING ADJ PUSHROD LENGTH DETERMINATION PUSHROD' YOU JUST MAY BE SURPRISED!
A completely primed motor makes for a nice first start up
Yup! Oil and fuel systems were both primed. I videoed my first start after the refresh. It fired up immediately and didn't make a single tick. You'd never know it was torn apart and not ran for three months.
Word. I changed the cam, had the heads shaved, installed new valve springs and lifters, had spring heights checked and adjusted and used thinner head gaskets- all of which affect valvetrain geometry and pushrod length. The $28 is a bargain for the Comp 7702-1 and the fun that comes with using it!
Fattdaddy
Ugh...I had a similar problem after my first attempt at the cam swap. Turned out to be a failed lifter that started wiping the cam, but we never determined the true cause. Sounded like a loud chirp when it was running but the engine made great power. Must be something else happening with yours if it's not making good power. I agree with the others here - time to tear it down. I'm feeling your pain, brother!
Did you ever find a solution to your problems I’m having the same issue
