Power seat does not move,
Silvi
Well it seems there is an electrical gremlin on the loose here. First the fan switch now a few dash bulbs and the climate controll lights, and now the DR seat does not work. I did check the fuse and they seem fine..So again I ask for your knowledge before I dive further in any ideas???? :hmm:
The 'ER
Minnesnowta
Make sure you have power to the motor and good power. Then you can make sure the switch connections are tight as with it being an intermittent problem it is likely a loose wire.
preshus
washington,IN
dose it click or make any noise at all when you hit the button or is it just silent . . .
mine wouldn't move for a while it would always just click and then one day it
finnally did but i guess it was stuck cuz the gears are half striped so its a pain
to get it to go any where and grinds the whole time
MeanieNJ
are your heated seats and passenger side windows out too?
S
Silvi
Hey guys sorry wasnt around to answer. I did check the fuses all seem fine and the motor does not hum or anything. I really didnt get to into it cause the wife has been really busy and so have I. Thanks for the reply all and when I do figure it out will let you guys know..
91RS
GA
Check the connector for the seat, seen the big power or ground melted many times.
S
Silvi
After working abit on the truck today found the motor that moves the seat front and back was bad doing some electrical checks. I also know it took out the seat switch out as well must have melted the contacts. When I jumped the power out from the plug at the switch it was a direct short. Now how do you change that motor cause I dont see any ways of removing it??
91RS
GA
You can only replace the entire seat track.
91RS
GA
You'll have a VERY hard time finding one used outside of buying a complete used seat. Only place will be a dealer or GM parts source.
gclibby
