Ppv help
mr tahoe
hey guys i just bought a youkon xl 2007 with the remote start and horns and all for 1500$$$ i bought this truck to replace my ex ppv tahoe interior and i was wondering wondering what do i need to swap from the yukon to my tahoe to activate the remote start with the horns and lights
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Who knows. When the sell them, they usually render those inopreratble. You have to trace the wires from the component back.
mr tahoe
mr tahoe
Yea thats why i bought a full truck i want to take the oem backup sensors the pedal adjustment and the ac electronic panel rather than having the old looking manual ones and since i have the hole truck i have everything from modules to wires to every thing and the dash witch is perfect not one single crack and I gotta say the dashbord feels diffrernt than the one in my tahoe it feels stronger if that makes any sense
AppocAlexx
Darth Appocalexx
Abilene TX
I would say you will need to gut the entire interior and lay out the wiring in the way that it should be set up in the truck and try your hardest to get diagrams (if you can read them) then compare your harness to the Yukon. I would be willing to bet that the just of what you want to do is all intertwined and it would be a major over haul to do that. May be better solution to fix the Yukon depending on what is wrong with it and then you have two toys.
AppocAlexx
Darth Appocalexx
Abilene TX
I would also say that the remote start would still need to be programmed when you figure out what needs to be swapped over and what not. I was looking into doing a factory remote start with mine and I would need to buy the kit which was like 300 if I remember and then pay a Chevy Dealer Shop to have the build sheet redone by GM. So your still looking at spending money after you get the parts installed. There is another aftermarket kit that is around 200ish and it uses your factory key fob buttons for the remote start and programs within a few minutes.
sumo
rhode island
Yea factory remote start is programmed in the bcm. Unless you have access to someone with a tech tool
mr tahoe
mr tahoe
Oh boy
And what about the ac controls ? Since i dont have the rear ac controls so i am planing on swapping the front controls and adding the rear ones
mr tahoe
mr tahoe
Honestly i thought about just taking the yukon but its soo rusty that i wont feel safe driving it its bent like a bananna wich means the chasis is rusted too,
Other than the rust problems the truck is perfect interior and drive train are perfect
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Oh boy
What do you mean "swapping" the front ac controls?
And by "adding" the rear controls, you mean adding everything in the rear, right? You can't just put controls back there without them controlling something...
mr tahoe
mr tahoe
I have the manual ac controls on the front with no rear ac controls , so i want to add the frobt ac controls of yukon along with the rear controls wich would give the back passengers the ability to control the ac
Caddychris
