pulling to the right
psfr311
Lawrenceville, GA
my tahoe has had a slight left hand pull since ive had it. even after alignments it still pulls slightly to the left
about 2 days ago i noticed that it is now pulling right. not 100% of the time but most of it
Both brake calipers are fairly new so i ruled out sticking calipers causing the pull
any ideas?
foreverfalcon40
check your tread depths, from the alignment being off in the first place it could have compramised the tires. Even if your car is with Spec it still drift. Whn you got the alignment done did they give you a computerized print out?
P
psfr311
Lawrenceville, GA
no crowns in the road
yes i have a computerized printout of the alignment
and the reason i find this odd is because i had it aligned a couple months ago.
and the direction of the pull just suddenly changed a couple of days ago
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
swap tires from left to right, does the pull change?
foreverfalcon40
Just bc the aligned the car doesnt mean it will last forever, ya hit hole,curb, or something not smooth and high speed it is going to throw it off!
Shadfrmdabull
