Because my gauge always reads empty. I know the gauge may be bad, but you've seen what it does when I turn the key to the run position. The gauge moves, so I know it's not 100% dead, so provided the PCM is getting a signal, and that signal is making it's way to the gauge, it should at the very least hummingbird. If the PCM gets no signal, then the sending unit is bad. If the PCM gets a signal, but the signal doesn't make it's way to the gauge, it's either faulty wiring or a faulty PCM. If the signal gets to the gauge but it still reads empty, then it's the gauge. I'm hooking it up to a Snap-On scanner on Saturday at my friend's shop, to scan for some other unrelated problems, but should I be able to see what the actual readout is on the sender, using that tool? Also, isn't there some sort of onboard diagnostic for checking operation of the cluster?
Now, if I recall correctly, I should read 40ohms at empty (probing harness between sender and PCM), and 250 at full. If I read a direct short, it's got to be a short to chassis. If I'm reading open circuit, it's likely a bad sender, but I'll have to check the connector to make sure it isn't toast.
