Question about a/c
El Capitan
Senior Texas Member
Grapevine, TX
Now I know some of you guys are in Texas and today in Lewisville it hit 104. I know some vehicals bump up rpms when the a/c is engaged is a 2001 Tahoe LT supposed to do that because mine does not. I have to give it a lil on the gas pedal at idle to keep it cool. Would like to know if there is something wrong so I can get this fixed QUICK!
ntxstallion
Yes indeed it is hot here in Dallas. I have a problem with my ac as well and looking to get it handled PRONTO.
chevyboy831
might need a recharge, but, when the engine is at idle, even with the idle kick up working properly, the compressor is still spinning slow. thats why when we check ac systems before and after repairs, we get an idle and 2000 rpm reading and the vent temperature gets colder when the rpms are up and better heat transfer at the condenser and blah blah blah blah blah. so what im trying to say is, get it serviced anyway, the fact that the ac is working means that the switches are working properly so the idle is kicking up im sure, but its not gonna kick up 300 rpm's, just enough to maintain an idle and not kill the engine. thats how its designed. if its really an issue, have the shop u take it to install an auxilary electric condenser fan. this will greatly increase cooling at lights. most shops will only go to specified pressures, not all will go above to please the customer as i do.
owner
I think it's about tuning and finding the right balance on your idle, and maybe also getting some more freon in your A/C. Take it to the shop and let them have a look is my advice.
El Capitan
El Capitan
Senior Texas Member
Grapevine, TX
did an evac and recharge at my shop pulled 1.38lbs out supposed to be 2.7 so yeah just a lil low. haha. works better now but still not cooling very well at idle, cruising at 80mph its a meat locker.
chevyboy831
well thats good to hear. and good to know its working well. like i said, you could install a aux fan to help u at idle.
walkerheartsfield
