Question about tire pressures
Tylus
South GA
So when I bought the Caddy it had the tires at I think 26 psi. P265/70/17 Goodyear Wranglers. Max load is 44 psi. So I put them at 44 psi to test things out until I had time to sort out the tire pressures.
Door jamb says this:
At 26psi, the ride was spongy and sidewall flex was scary.
At 44psi, the ride is harder than my Excursion, but tracks nicely.
I don't trust the 30psi requirement. I remember the early 2000's and Firestone incidents in Texas (was there and had a set of the tires).
What do y'all recommend? I'm currently at 38psi and testing. In the picture below you can kind of see where the outer edges are not wearing and only the middle is when at 44psi. I intend to keep lowering pressures until I get a nice even wear pattern, but still maintain a safe margin above 30psi.
Been a while since I had P rated tires...
oh1yukonslt
Wikitsikone
N. Idaho
Try 35psi that may be the sweet spot. Try that and draw a chalk line across the tread to see how the footprint is
Tylus
Tylus
South GA
footprint at 44psi has the outer edges raised...center only pattern
scrub pattern at 38psi is much much better. so is the ride. still a tiny bit of outer edges not touching
I'll try 35/36psi tomorrow and see
lordflash
