Question for those running Tony's 3-4/5-6
NathanJax
Vacation Nathan
Administrator
Jax, Fl
stock, but running the re-locator brackets
dropmech
dropmech
Puddle Pirate
Coral Springs
Thanks Nate. I'm actually installing the rear hardware kit this weekend. Hoping to get the 5/6 kit soon.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
remember to move the swaybar over in rear and also redrill the 2 holes on the bracket mount over 1 inch on the drivers side swaybar axle bracket.
dropmech
dropmech
Puddle Pirate
Coral Springs
Thanks! Yeah I did that a while back when I installed the spohn pan hard bar.
04blackout
Stock with the brackets here. One of these days ill swap out to the actual adjustable bars though
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you do both the upper and lower you can push the rear axle back to center it in well.
NOTE= Buying only lowers will give you so much negative pinion angle truck will vibrate bad. Had a guy that just bought lowers from a online place and moved the axle so far back to try to center pinion was facing like -8. I always set people up with both upper/lowers. Make lowers 9/16 longer and uppers 1/2 inch longer.
Stanlee83
