These picture are bad to but not shakey will try again tomorrow night with a different camera if you want, this one is crappy. At any rate all interior and exterior marker were superbrightleds
Here was my order:
Qty | Product / Options | Price/ea | ============================================================ 2 | 4210-xHP6: 6 High Power LED Festoon Bulb | $ 14.95 | 4210-CWHP6: Cool White ------------------------------------------------------------ 20 | WLED-x-x: 1 LED Wedge Base Bulb | $ 1.39 | WLED-W-120: Cool White 120 Degree ------------------------------------------------------------ 1 | EP29L: LED Bulb Flasher Unit | $ 12.95 | ------------------------------------------------------------ 2 | WLED-x-x: 1 LED Wedge Base Bulb | $ 0.79 | WLED-A-120: Amber 120 Degree ------------------------------------------------------------ 6 | 74-x: Wedge Base LED bulb | $ 1.19 | 74-W: Cool White
the 74 wedgies were installed in the hvac head for illumination and a/c-recirculate indication (polarity sensitive)
WLED-A-120 were installed as the front corner makers
4210-CWHP6 were used as the dome lights. the second set of pictues were with the cover lens removed(I like better) They are the brightest festoons they have.
WLED-W-120 were used in dash for instruments, rear plate, doors, pivoting reading and front floor. I was in a hurry to get a different look but will make some changes in the near future.
For floor will do WLED-WHP18-SP $15each. being open sockets they should fit and make the front floor look like a bomb flash
reading lights WLED-NWLX #10each bright but still directional for less distraction to others.
front markers WLED-AHP9-T $12each I think the lens has an internal reflector to take advantage of a 360 bulb
doors and rear plate don't seem to have reflector and are installed from front pointing to the rear the only on side lighting bulb that would be perfect are
WLED-xHP6-RAC
unfurtunately only in blue or amber and maybe to long for rear plate enclosures and the socket terminal would have to be one above the other and not side to side because of bulb orientation.360 would work but seems like wasted light.
Also I installed anzo tails and parking led conversions but the backups in tails were still a regular bulb so most likely will convert to 3157-W45-T $25 each. I think hids for reverse take to long to became really effective for short reverse trips. To much?
