Race gas safe for 02 sensors
Wrisktaker1
Waldorf, MD
Has anybody mixed race gas with with pump gas and not have it hurt your 02 sensors, what's the pros and cons of doing it?
Sasquatch
Orange County N.Y.
If it`s leaded fuel it could hurt O2 sensors and catalytic convertors but i would imagine using it once and a while would be harmless especially if you dilute it.
Are you using it in your truck?
01ssreda4
I run MS109 in the Camaro and so far so good. As stated above dont run leaded.
hoe
I've done this a few times. Especially when hitting a long road trip. You can feel a bit more power and the fuel takes a good bit longer to burn. I normally just mix 5 gallons with 20 gallons of 93. My 383 loved that mix.
Wrisktaker1
Wrisktaker1
Waldorf, MD
this is what i was referring to........
Not Vehicle Specific
  • Price: $21.99
    ADD TO CART
    Hot Deals & Savings
    FREE Shipping
    On orders $75 or Greater and FREE Shipping to APO, FPO, DPO addresses. See DetailsFeatures & Benefits
    VP Racing s Madditive Octanium is a race & off-road octane booster, increasing gas octane up to 8 numbers (80 points). It helps to improve throttle response and acceleration and may help reduce or eliminate knocks and pings caused by low-quality fuel. Madditive Octanium is not meant for vehicles equipped with O2 sensors or catalytic converters. Use 32 Oz. of Madditive Octanium to treat up to 10 gallons of gasoline.
    • Treats up to 10 gallons
    • Increases octane up to 8 numbers
    • Increases horsepower
    • Lead substitute
01ssreda4
Just buy some MS109 and mix some in with your fuel.
hoe
I would put the 100 oct tune and run 100 oct. Seriously you will not optimize anything without the correct tune. I personally have used 100 oct mixed with 93 in my above post. I have also used additives and can say they do work by themselves as well.
Get a computer and log then make adjustments then log some more...
Ajoseruiz3
