Radio problem
atsewell
About a week ago I was messing with the wires on my head unit and after I couldn't get it to turn on. Turned out a fuse was blown so after replacing that it seemed to be working fine. The next morning when I turn off my street the speakers cut out but the sub was still going and the head unit had power. I didn't have time to mess with it until today. After checking the connections on all the wires I found they were all connected just fine. So I hook everything back up and fire it up but now there is no power to anything. I already checked all the fuses and they are all still good. Where should I go now?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
dirty or broken terminals. but if you bench test it and the sub pre-outs work but the built in amp outputs don't it might be in a protective mode or the radio is suffering from a problem with random or multiple symptoms.
SunlitComet
OBS Jedi-Do Good
Have you bench tested it or otherwise know for sure it is internal to the radio. if it is you can look for cold or broken solder joint on the pcb's but it may be best left to a repair shop if you are not familiar with the setup or methods of electronics repair.
DaisyGirl
