Random jerking
dadwagon95
Asheboro, North Carolina
Hellooo dadwagon once again... With the 04 Yukon 4x4 with 35x12.50x20 20x12 offsets, no lift just torsion keys turned up all the way. I finally got the rear end in her and when I drove it again I started getting a kinda scraping sound that goes around with the wheel. It use to stop when hitting the brakes now it doesn't you can hear it the whole time your driving. Occasionally you'll get what I describe as a loss of control basically,it's like the truck jumps left and when you try to turn back right it's like weird almost like it has no effect steering it until you hit brakes... Now I've shaken it down, changed the sway bar links, and the idler arm. It doesn't have your typical wheel bearing / ball joint movement. It's got side to side but the whole steering system moves not the single wheel. So I don't suspect tie rod ends... Lemme get some opinions fellas! !!UPDATE!! I took her to the car wash cleaned er up and the house went away... STILL HAVE A "FLOATING" front end though.... And its got me completely stumped like I have absolutely no good guess on what it could possibly be. The best way I can describe this is the truck body feels like it's floating off the frame & the steering almost does I guess a very very low grade death wobble like a soft wobble from left to right then back to normal. Any advice is GREATLY appreciated... This is my only transportation and my 2 year old rides in it..
Donal
Americus Georgia
Search in the technical section for lower control arm position and then set the control arm to that position. Both sides.
Rednim
