mason313
- Joined
- Jul 9, 2010
- Posts
- 249
- Reaction score
- 53
Well the missfire started about a week ago on the freeway when I was trying to pass someone. Was fine the rest of the time until the other day it would missfire anytime I got to around 3k rpms. Now its shaking real bad at idle. So I went and checked the codes I had a random missfire. Didnt pin point a certain cylinder. The plugs and wires where dont in the summer but I went ahead and changed the wires no change. I started getting a 02 sensir code for bank 2 so I replaced the 02 sensor. Now its reading a maf code I cleaned the maf with no change so I tried one off my buddys truck still no change??? Im also getting a bad squealing noise from the drivers side of the motor. I read something about a missfire and squealing sound could be 1. Worn camshaft lobe and/or lifter roller2. A sticking valve3. Valve leakage4. A broken valve spring5. A collapsed AFM (Active Fuel Management) lifter.
Any help would be great guys thanks
This is on my 04 Denali xl
