Rear Ac Issues
CCROCHET
I had my compressor replaced and charged. The rear ac will not blow cold or hot. It just seems to blow outside air, any thoughts? Thanks
chauncey0337
MLT, WA
Or, your rear heater core may need to be flushed. I had a similar situation with my front heat. You will have to get into the rear ac system and listen to see if the actuator moves when you change it from hot to cold.
dylansmashed
