Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Need to pull my axles to do backing plates and back brakes. 2005 yukon 5.3 AWD. My diff is a 10 bolt. My problem is my rear axles don't push in far enough to remove the c clips. Any suggestions?
You have to remove the cross pin. Then the axles will slide far enough in to remove the clips. The pin comes out with an 8mm bolt. Be very careful with the bolt. Breaking it or stripping it turns into a bad day
Ok so I got it sorted. The axles just wouldn't push in far enough for a 1 man show. However, put a ratchet strap around the axle and tightened it up, slid it in enough and got my stuff replaced. All new axle seals, rear brakes, backing plates. Just got to fill the diff and I'm good to go!
Does it have the G80 posi? If so I can see how it was tricky to get them out, takes me a while to find a thin set of pliers to dislodge those, as a magnet is never strong enough for me.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
