S33k3r
I checked each of the fuses with a multimeter. Not an expert on the multimeter, mind you, but I checked resistance and each fuse had continuity. I am paused at the moment because 1) My Tech2 won't get here until next week and 2) I have to replace the shocks on the hatch so I don't get smushed. Thank you so much for the help, and I'll report back with what I find.you can check all the fuses, however if a fuse blew there is usually a reason why, occasionally a fuse may just give up the ghost for no apparent reason, but I would get back there and pull the paneling off and start checking things with a volt meter without a tool like a tech2 you kind of have to do most things hands on and even the tech2 can only get you so far. there are a ton of youtube video's showing how to get the panels off it only takes about 5 minutes or less to get access to the rear hvac system.
Also, it looks like I am about to get an '04 parts Suburban. It was parked because it wouldn't start, then sat for 3 years. Not sure how I'm going to attack that one, though I am probably gonna grab ammo for theparts cannon and then flip the remains. Thank you all, so much, again!
