rear brake lights with LED bulbs, turn signal problems
kenner
Just installed 4 new LED brake light bulbs, now when I use turn signals they flash super fast and dash screen says turn signal improper?
What goes with that, all brake light bulbs work fine.
Thanks
kenner
The fast flash is called hyperflash, and you need to install resistors in those circuits, in order to slow down the flash. I left the hyperflash on mine, as I believe that the fast flash attracts more attention from other motorists, and after all, that is the purpose of the directional signals in the first place. I will note that hyperflash is illegal in some states. If you want to install resistors, they are most likely sold at the same place that you purchased the LEDS.
I do not get any dash screens saying turn signal improper on my '07, but perhaps your truck is never, and the warning systems are different.
2COKane
