Rear captain chairs install.
ShaginWagon
Friendswood, TX
Was going to pick up a pair of captain chairs for the rear and was curious on what the install would look like. I currently have my single 3 seater bench in there now and took out my 3rd row. I think I read somewhere that the install is straight bolt on? Could be wrong. Any insight on this would be awesome. Thank you.
I have read a little bit about it before, I think it can be done as long as the platform is the same Tahoe seats for Tahoe, Suburban seats for Suburban, from what I understand you cant swap the Tahoe seats into the suburban (or visa-versa) the brackets are in a different position or the floorboard is different something of that nature, and I think you have to have the whole bracket assembly not just part of it. I know people have done it. someone else will probably chime in that has done it or knows more specifics
select127
Florida
Direct bolt in SWB to SWB. Did it in my Yukon, had captains and swapped to a bench seat out of a Escalade. You may want to get the trim pieces that cover the frame and bolts as well.
