electro
Dont know if this is supposed to be in technical or in general?
So tomorrow I'm changing the transmission and im going to replace the rear main seal as well. I bought a remanufactured trans from the deal for $1506 w/tax in. Plus a rear main seal and some fluid. The trans and TQ came prefilled.
I got a rear main seal from the dealer with the plastic installation sleeve. Anybody know how that sleeve works and the order of that?? Apparently this sleeve replaces the J tool...?
Also...For the rear main seal housing cover. What is this i read about alignment pins? Where are they? Are they on the block right now...and I just need to use them again? Probably worrying too much about this one.
I did not buy a rear main seal housing cover gasket. I plan to run a 3mm bead of RTV. Sound cool?
so anyways, you remove the trans, than remove Flywheel and than you can access the rear main seal cover HOUSING. Remove the housing and than remove the seal. Install a new seal, install HOUSING with RTV, INSTALL flywheel, torque to specs. BOLT ON A TRANS. T-case. Driveshafts. Vrroom vrroom. Miss anything?
THANK YOU FOR YOUR HELP! If you do respond anyways.
