Rear defroster...
Flyhatch
Pittsburgh, Pa.
I bought a 1995 2 Door 4wd with 105,000 about a month ago. I got the oil changed as well as new plugs wires air filter. It runs strong but it does have the intake coolant leak and the heater fan dosent work on high. I already had the blower resistor replaced and It still dosent work so I ruled that out.......
anyway :)
I am pretty sure the rear defroster isnt working. The light comes on but I dont think any defrosting is happening.
I checked the fuses and it looked like there should be a 30 amp fuse in the RR Defroster spot but there wasnt one so I took the xtra 30 amp and popped it in and tried it and what I found was that now the radio and the rear wiper didnt work :) so I changed it back. I need my tunes.
any help will be greatly appreciated,
e
Sobe Superman
Wisconsin
Look behind the fuse block and make sure there are not any melted wires. Then put that fuse in and turn defrost on and off to see if it has any effect in radio power. if radio does not turn on check the power going to radio behind fuse block if there is any power especilly if low power and wires heat up then there is a short, Trace wires to find the short
PD2770
