Rear hatch not opening?
pa-yukon
Rear liftgate not opening?
I've had my Yukon XL for 11 days now, and for the last 2 days my rear liftgate will not open. If I press the button on the RKE it starts to open, gets about a foot up then beeps and closes. Same thing if I press the button from inside. There is nothing blocking the liftgate from opening or in its way. Anyone else have this issue? I've contacted the dealer but haven't heard back yet.
MortMan
S.E. Michigan
I believe that there is a TSB out there for this problem. Sonething about shims needing to be removed from under the rear spoiler.
Tahoe14
Central Fl
There is actually a recall dated 12-8-14 "Power Liftgate Inoperable". Document ID# 4042119, Recall # N140300, Service Update #14300 . Hope this helps. Good luck.
P
pa-yukon
Thanks for the info! Is there a place I can go to online that shows the that recall? I didn't see this one at http://recalls.gm.com. Will need to get this fixed asap.
Tahoe14
Central Fl
The Dealer gave me a copy and it has to do with replacing the actuator arm, top left upper side of tailgate. I am not sure if this is your issue but on another GM website it had to do with the spoiler hitting. You may be able to Google that one. I did a Google search on my recall but nothing turned up.
eod_tech
