Rear Pillar Color Matching
gmc_z71_95
The Yukon's are black and the Escalade's & Tahoe's are color matched. Can I order pre-painted Tahoe ones for my Yukon? Is installation straightforward?
Tahoe "Graystone Metallic" is the same as the Yukon "Steel Gray Metallic", right?
KMeloney
Why not just take yours to a paint shop and have them painted to match? Personally, I wouldn't assume that the paints are the same color, especially when Chevy has 3 variations of "black" for the Tahoe...
To answer your other questions, you can order from gmpartsdirect.com. Check there to see if you can get them already painted. Once you have them, there's one screw and a bunch of wedge tabs that hold the pieces in place. Super-easy to remove/replace yourself.
Fast55
Ventura County USA
You cannot buy them color matched, they must be painted. Unfortunately, it's almost impossible to get a perfect match for any metallic color, but they're far enough away from the rest of the body that it's not usually an issue. Getting the Escalade appliques painted at my local dealer is $100.00.
EdwardsD
