Rear Speaker wiring harness
wesleyeudy
I have a 2004 Yukon Denali that I just bought. It has the Bose Audio system. I noticed none of the rear speakers were working, but the front speakers and rear headphone outputs work fine. I pulled the center console apart to access the amp to see if I could find anything. I started taking ohm readings of the speaker circuits to see if I had any shorts. To my surprise I had open circuits to all the rear speakers. After digging a little deeper I found a plug on the front side of the amp that was not hooked up to anything. I traced the rear wires from the plug to the amp and found all the rear speakers tie to this unhooked plug. I can't find any other loose connectors though so I'm not sure where it's supposed to go. Can anyone tell me how the rear speaker wires were routed to get to the center console? Any ideas are appreciated! Thanks
W
wesleyeudy
I found the other end. It was under the carpet next to the drivers seat. Everything's working as it should now.
jfrief
