Rear Sub Wiring
Diverdown1969
Hey all! I've got a 2003 Tahoe and was curious about the rear sub wiring. I've got the Bose sound and was wondering if you can hook an additional sub in the cargo spot AND run the one sub in the center console as well? Is the wiring run to the back for a sub even though a factory enclosure is in the console? TIA
One additional question. When locking the doors and setting the alarm from the key fob, there is not audible honk from the horn to indicate the alarm is set. Is that normal? Or is there some setting the previous owner changed? This is the factory alarm we are talking about.
ntxstallion
On the alarm, it is a setting that has been changed. Should be able to be changed on the radio if you have an 03. Just hold the display button with the radio off and the options will pop up.
Have no idea about the amp.
OmarR
Indianapolis, IN
You can install a sub back there, but you will have to install everything, including wiring. There is no wiring going back there for 03+ models.
DennisWM
