Rear windows won’t roll down
K9Gunner
I have a 2005 Yukon and both rear windows will not roll down. When I use the switch on the drivers door to try and roll them down all I get is a click from each door in the back.
bill1013
Waianae, Hawaii
Do they work when you use the switches on the rear doors themselves? Also, sometimes if they haven't been used in a while they stick. I had my daughter hold down the switch while I pressed my hand/palm downwards on the window itself. They came down with a little help, so I ended up taking the panel off and lubing the gear and cleaning out the window runners. Also, my windows don't go all the way down so it was a pretty quick fix.
K9Gunner
K9Gunner
The rear switches don’t work either. I ordered a new switched hoping that would be it but they still didn’t work
davemitchell117
