reattach door rub guard trim...
hillstrubl
what kind of adhesive is everybody using for this? Silicone seems crude, epoxy is too permanent... I need to also figure out how to hold pressure against it while whatever I use cures.
Ideas?
I'd use a bit of clear silicon caulk, with duct tape to hold it on place for 24 hours. The caulk has adhesive properties, but can be easily removed if needed.
ReaperHWK
They make trim tape made especially for that. Look it up.
Believe it’s called mouldong tape. 3M makes most of them.
