Regearing with stock tires
teMoony
Hey there,
My Tahoe is re geared to 4.1 but i still have stock tire size and no lift. Anything i should be aware of ? Any harm in that setup ?
Gzes
the drifting 2dr
Wichita tx
Gas milage will be different and you might be running different rpm and may strip out the gears. Id get the tires first then the gear imo
SunlitComet
OBS Jedi-Do Good
unknown at this time.
like bow said, quicker of the line acceleration speedo and shift points will be off if axle ratio is not programmed in the pcm. mileage will be a bit lower then usual.
Donnie Yukonie
Yates Caretaker
i didnt know you had to flash the pcm when you get new gears?
bowtiefreak
No Quarter
Near Philly
Yes sir. ABS gets a little crazy to as it thinks the rear tires are spinning at different speeds from the front. Throws off shifting too.
In my opinion, 4.10 on a 31-33" tires is perfect. Again, my opinion.
retorq
Kingman AZ
He doesn't say what year truck he has, pre 95 I believe there was still the VSS box that have jumpers that can be manipulated to read correctly. 3.90s with my 30x9.5 tires reads just about dead on.
BigBodyBurban
