Remote wire
AMG
seeing how this is my first post i will have to put some photos of my yukon up, but until then i have an problem.I ran some cables last night for my amp, and am looking for something behind the stock deck to connect my remote wire to. I tried searching but nothing came up. As well i don't have a test light or many tools (recently moved) so if you guys can tell me the wire colour in which harness to grab it would be great.
Its in a 2003 Yukon denali, with a stock bose system.
Thanks
Johnny
nytahoe
"Tha Butcha"
new york
you can go to the side of the dash and get power from the 10 amp radio fuse
riso79
So Cal
Depending on the amp when they receive power from teh RCA's they turn on automatically. Even when you use the high low input of just speaker wire they turn on. If not, I would use the accessory (yellow, in most cases) from the deck.
A
AMG
Its an old amp, need a remote wire, usually it is yellow but there isn't one behind the deck this time. i will probably just run it from a fuse like the others said. right now i have it running of a constant wire and am unscrewing the wire when i get out of my truck.
Thanks for the suggestions
jpaeltz
OKay on the passenger side dash (opposite of the fuse box) there are a bundle of wires. Look for a bundle of brown wires. I used my test light on the first one I spliced and it worked fine. It's easy to tuck the wire behind the glove box to wherever you need to go.
Chevgent559
