Replaced door now service airbag light?
maxamillion125
I recently replaced the passenger side door on my tahoe and right after I connected everything and turned it on the service air bag light came on and its been on for weeks now. I'm guessing its somehow related? Anything I can do or check before I take it into the dealer?
M
maxamillion125
anybody? I disconnected the negative battery cable to see if the air bag warning would come back and it did. I looked under both front seats to see if there were any loose wires or connectors and everything looked ok but I'm not sure what else I can do?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
How about a Year, 4WD/2WD/AWD, Trim Level and engine size to start with? Also helpful would be an RPO label pic taken (on the backside of your glove-box.)
M
maxamillion125
2004 AWD, 5.3L V8, does that really matter?
M
maxamillion125
Can anyone else help? I found a wire with a connector that looks like it should plug into the airbag impact sensor but I can't find where it is. Maybe the door I switched out didn't have an airbag impact sensor?
M
maxamillion125
Ok so I just ordered a new impact sensor, I should be able to just plug it in and the check air bag system light will go away??
Thanks for the help guys.
Roblusk
