Replaced Head Gasket/Won't start
BDoolz
1999 Tahoe 5.7 Vortex, replaced Head gasket/manifold gasket. On reassembly placed #1 to tdc installed distributor with marks lined up. Finished assembly after, try starting won't start, engine turns over additional 2 times after cranking. Is this a timing issue, or possibly issue with valves not adjusted right? Or something completely different, any comments would be greatly appreciated, thanks
ccapehartusarmyINF.(ret)
Gilbert AZ
i would say timing issue then
that motor has hydraulic lifters to no valve adjustment needs to be done just make sure the rocker arm bolts are all torqued to 22lbs
Tehboogyman
Most likely a timing issue. Put #1 at ~20BTDC on the compression stroke and stab the distributer. Put a mark on the bottom side of the distributer lined up with the #1 plug wire. When you stab the distributer line the rotor up with the mark you made. It should fire right up.
willxfs
No. 1 @ TDC "on the compression stroke" is key here. If you are 180 degrees out, then you'll definitely have starting problems.
B
BDoolz
Will, pull distributer and retry. As far as rocker arms us it 22lbs on the rocker arm bolts? I've read both 22lbs then most say find zero on push rods, then 1 full turn. Was thinking the 22 was for the rocker arm studs not for the nut on top?
B
BDoolz
I also went and picked up a compression tester so will go ahead and check each cylinder while I'm at it
B
BDoolz
Not sure I know what ~20BTDC is. I know what #1 at TDC on compression stroke is.
Teninback
