Replacing Door latch video or write up???
Geoff
Hey guys, new to the forum. I've spent more time searching than it would
probably take to just do the job. Does anyone know of a video or write up on
replacing door latches and strikers on 88-99 chevy trucks? There is a great
video https://www.youtube.com/watch?v=1isrUB9N7tI. It shows you how to
take apart the whole inner door. I also read on another forum that you can
remove the latch from that access hole on the side of the door but there were
no details. Any input would be greatly appreciated, thanks for your time guys.:)
jerryjoe28
That Guy
cabot AR
1AAuto has youtube videos to do a ton of stuff on tahoes. I would check them out
Geoff
Geoff
Thanks, they do have a lot of great videos. None about door latches and strikers though.
Maybe most people just live with the door rattle. I had two of these trucks and they
both did this even after bushing and pin replacement. I will document the job when I get
around to it. LMC truck has door latches for 50$.
jerryjoe28
That Guy
cabot AR
i just replaced mine a few weeks ago. is yours just not closing tight enough? if so loosen the striker and see if u can move it in any. the hole is bigger than the striker bolt
Geoff
Geoff
I have tried that. The striker and latch are so beat up it didn't make any
difference. I'm rocking the electrical tape on the striker right now. Did you
replace the door latch? If so, did you have to take the inner door panel
off?
jerryjoe28
That Guy
cabot AR
I didn't replace my latches I just pulled them out cleaned them up and regressed them. you will deff have to remove the inner panel as the connecting rods for the lock and handle. just be warned it is a tedious task, and will take some time.
95escahoe
You need to pull the panel to do the latch, had it done a few wks back used the LMC one
Acts822
