Hello, first post here, nice looking forums.
I have a 2005 Chevy Tahoe, my gas gauge reads different levels every time I start it. From some other threads I found it sounds like the sender unit is the likely culprit. So that is what I'm plannin on replacing. The tech at the dealer says I should replace the fuel pump unit along with the sensor. Posting this here to get additional input on whether I need to replace my fuel pump with the sender or if I can safely correct the problem just by replacing the sender.
Thanks,
Ryan
Thanks,
Ryan
