Resetting keyfob on yukon 2022
JLMBT
Does anyone know how to reset the keyfobs on 2022 yukon denali? I have wo keyfobs, and every time I try to set my memory seats, to #1 setting...it doesn't beep to let me know that it is set...I would like to reset both the keyfobs and restart...let me know thanks. I need specific instructions on how to do this thanks
texasdriver
Have you tried pulling the battery out? I had some issues with the fob going to sleep, so I pulled the battery for about a minute, and reinstalled it.
WalleyeMikeIII
Sunny and Snowy Minnesota
Note, the KeyFob is not specifically the issue w/ memory seats.
The memory seat function is tied to the #1 and #2 buttons...
The Fob is then used to define what driver memory functions are associated with which fob....
Note, you can program both seat positions, and the exit position with the buttons, regardless of which fob you used to turn on the vehicle.
And you can set the seat position to either of the remembered locations by holding the desired button.
So, if you cannot program either of the memory seat locations by following the procedure in the owners manual, and then recall them by holding the button, then you have an issue w/ the Seat Memory Module, not the key fob.
You mention you can't get the double beep after hitting Set and then #1? See step 4 in "Saving Seating Positions" on the page 41 excerpt below. Are you being quick enough? If you can't program #1, but Can #2, then maybe you have an issue w/ the switch or the module.
DontTaseMeBro
I seem to be having a similar issue. Pressing the “set” button only brings up the ability to save the seating position to button 2 only according to the on screen prompt. If I hit button 1, nothing beeps. The weird part is button 1 does work because if I hold it, the seat gets recalled to whatever position it last was able to store. I’ve removed the vehicle battery several times already. Any other ideas?
tanguycryms
