Resonator Deleted
gnarpow
Denver, CO
Looks so much better! Now you just need to paint the other part of the pipe black to match.
Administrator
What kind of paint did you use on that tip? I'm assuming something like engine paint or something that can hold up to the heat? I like the direction your'e going here! :)
Another area of concern is the exhaust coming out right next to that white paint. Make sure you keep it cleaned very regularly other wise the exhaust could have a tendency to "stain" that white.
RydnDrty
RydnDrty
Houston, TX
You got it Jacob... the only thing on the outside of the truck that isn't black or white is the headlights....the stainless tip would have thrown that off...
I did use the engine enamel paint, and clear....gonna see how it holds up...if it doesn't, then I might have to try powdercoat...
And it is a SLP resonator delete, Alex.
AbroN124
