Retaining RSE with aftermarket flip down.
OKREDDIRTZ71
Okc,OK
Hey guys I'm done some searching but haven't found a definitive answer. If I replace my stock bulky small screen flip down with like a big 20in flip down does anyone have a direct how-to do this in a z71 hoe?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
IF your OE radio was the source of activating RSE (by hitting the source button) you can use this harness. If activation was somewhere else like the rear controls, then no you can't
Meta GMOS-014 - GM Onstar/ RSE/ and retain the warning chimes module
The GMOS-014 is designed to retain Onstar/ Rear seat entertainment (RSE)/ and retain the warning chimes that are normally lost when the OEM radio is removed. It also provides a 12 volt accessory output for aftermarket radio operation.
The GMOS-014 provides a mute/ parking brake/ vss or speed sense and reverse output to make installing an aftermarket navigation radio simpler and less time consuming.
08grey
PAC gmrdvd if you already have the radio installed. It plugs up behind the radio or in the center console.
OKREDDIRTZ71
OKREDDIRTZ71
Okc,OK
I might not be understanding right. My factory head unit is the Delphi NAV unit. I'm not wanting to change head unit... I want to replace the factory overhead DVD Player and keep RSE.:slap:
08grey
You can use the pac interface. It gives you video output. Google add headrest tv's to rse. Same idea.
